Date/Time: Sun, 13 Jul 2025 07:18:55 +0000
Add symbol to Trading Evaluator - Delayed
View Count: 376
[2024-04-18 20:01:39] |
User846910 - Posts: 13 |
Hi, Is it possible to add NIY to the CME for the trading evaluator? Thanks |
[2024-04-19 14:35:57] |
Sierra_Chart Engineering - Posts: 20186 |
Yes we will work on this. It will be done over the weekend.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-19 14:36:04
[2024-05-09 20:25:19] |
We apologize for the delay with this. We did not get this done, when we said. There was additional work that had to be done to support this since the currency is in JPY. It is now added and properly supported for trading. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-05-23 22:10:53] |
Thank you for adding the symbol. There is a strange issue now where in the "trade activity log" the P/L and other statistics are adding/subtracting the Yen P/L without converting to the base currency (USD) first. However, in the "trade account monitor" it looks like it is being converted to USD. Maybe this could be fixed fairly easily? |
[2024-05-28 04:31:51] |
Refer to this setting to do the currency conversion on the client side in the areas you are mentioning: Global Trade Settings Windows: Common Profit/Loss Currency (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
