Date/Time: Thu, 10 Sep 2026 07:49:58 +0000
trial login
View Count: 1433
| [2014-08-14 16:24:22] |
| User69536 - Posts: 2 |
I cant use my trial login. When i try to update platform and click YES, platform just shuting down and nothing heppend next. I cant connect to data feed coz my package not enablead all of them
| [2014-08-14 17:46:19] |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-08-14 18:59:07] |
i still cant update platform, its just shuting down after uploading and conforming for update
| [2014-08-14 20:33:31] |
Download Sierra Chart from this page and update it that way: https://www.sierrachart.com/index.php?page=doc/download.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
