Date/Time: Thu, 19 Nov 2026 13:27:35 +0000
Trade management by study does not work
View Count: 1032
[2024-04-15 15:26:53]
User58776 - Posts: 18
Activated trade management by study but it does not work.
It should follow the 20 ema study I have but upon enabling, it does not move the stop
I tried the setting with timing (every n seconds) or 'on bar close' it does not work
i tried settings 'nearest stop' or 'oco group 1' it does not work
see attachment
please provide a solution for this.
thanks
best regards
Jeroen
Private File
[2024-04-15 17:37:02]
The Trade Management by Study" study is not "Enabled". That is, the first Input for "Enabled" is set to "No", meaning it is not going to do anything, which is what you are seeing. You need to set this to "Yes" to have it work.
You can also setup a Control Bar Button to toggle the "Enabled" Input. This is what the Input for "ACS Control Bar Button # for Enable/Disable" is for.
Refer to the following:
Attached Orders: Trade Management by Study Input Settings
[2024-04-15 17:42:44]
Dear,
logically that is just the screenshot.
I of course enabled it, and it does not work...
best regards
Jeroen.
[2024-04-15 18:04:27]
Other items of note:
- You have the Update Increment set to 5 seconds, so you have to wait 5 seconds for anything to occur.
- You have the "Trailing Offset" set to 14 ticks, so it's possible that this is too large for it to move the Stop.
You can set the Input for "Detailed Logging" to "Yes" to get more information in your log on what is occurring.
[2024-04-16 15:09:36]
Fyi, by logging found out that auto trading must be enabled (on chart and global)
Then it works.
Best regards,
Jeroen
[2024-08-15 02:55:13]
User488241 - Posts: 44
Thanks for posting that auto trading must be enabled. I was having this same issue and it saved me a lot of trouble.
