Date/Time: Mon, 20 May 2024 01:27:37 +0000
Label Column Next to Price without any other DOM columns.
View Count: 85
[2024-04-15 14:39:51] |
User92573 - Posts: 491 |
Dear Support I have read through the numerous threads re adding a column to be used by Studies i.e. Study Settings >> Subgraphs >> Name Label "Label Column" BUT ... what I'd like to do and have seen, is a label column without needing to include any other "Customise Chart DOM Columns" or associated columns other than the "Label Column". John writes:
The only way to do what you are asking is to do the following: - Ensure that the option for Trade >> Trading Chart DOM On is not enabled (no check mark). - Ensure that the option for Trade >> Show Market Data Columns is enabled (has a check mark). - Go to Trade >> Customize Chart/Trade DOM columns and add the Buy Order Column and Sell Order Column to the list of displayed columns. This will remove the Size or Size/BuySell columns if they were there previously. - Add the Label column if not already there. - Select OK to close that window. You should have it without the Buy/Sell columns and just the Label column. However I cannot see "Trade >> Show Market Data Columns" and I have seen numerous examples of sierra charts that seem to show the Price Column with just a label column, and nothing else. Any assistance gratefully received. If this requires some form of ACSIL or custom programming an outline would be very helpful. Many thanks. |
[2024-04-15 17:29:28] |
John - SC Support - Posts: 31734 |
The option for "Trade >> Show Market Data Columns" is just below "Only Orders From Chart". This option may be grayed out if the option for "Trading Chart DOM On" is enabled. The instructions you reference are correct. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
