Date/Time: Sun, 19 May 2024 00:03:13 +0000
Routing order to various venues
View Count: 1003
[2014-08-13 18:06:46] |
joshtrader - Posts: 442 |
Let's say I have a TD Ameritrade or Interactive Brokers account and hook SC up to it. Is there a way in SC to specify which exchange to route the order to? ARCA, BATS, EDGEX, etc? If there is not a way, is there a default route (maybe SMART in IB)?
[2014-08-13 18:18:44] |
In the case of IB you can definitely control the exchange. The exchange is part of the symbol specification. Refer to this page: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock For any stock symbol you can specify the exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 18:18:55
[2014-08-13 18:24:23] |
Excellent, thank you. Can you think of a way to make it easy to change venues quickly without changing the chart symbol itself? Also, let's say I have a chart of "AAPL-STK-BATS" and place an order on "AAPL-STK-ARCA" -- will I see the order on the chart of "AAPL-STK-BATS"? |
[2014-08-13 21:19:29] |
You can use the Associated Watchlist to change the symbol of a chart quickly: https://www.sierrachart.com/index.php?page=doc/doc_SwitchingSymbols.html#AssociatedSymbolList Also, let's say I have a chart of "AAPL-STK-BATS" and place an order on "AAPL-STK-ARCA" -- will I see the order on the chart of "AAPL-STK-BATS"? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 21:20:18
