Date/Time: Sat, 04 May 2024 22:45:01 +0000
CQG FIX Password change
View Count: 1085
[2014-08-13 17:51:41] |
User33803 - Posts: 40 |
Hi, Is there any way to change the CQG FIX password through Sierra Chart? I contacted CQG looking for a way to do it and they have told me to contact you ?!!? |
[2014-08-13 18:20:22] |
There might be a way through the CQG FIX protocol implementation, but if there is we do not have it implemented. So contact your broker and have them change your CQG FIX password. After they do that, update it in Sierra Chart through Global Settings >> Data/Trade Service Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-14 15:10:23] |
Yes, CQG has just told me that there is a method within the API to change the password, so you could add a function which could do it. I think to have this feature is not critical but could be interesting to have it in SC. It is up to you.
