Date/Time: Sat, 18 May 2024 21:55:30 +0000
Diferences between CQG & Teton
View Count: 237
[2024-04-07 12:17:29] |
user8888 - Posts: 159 |
I recently switched from CQG to Teton and have noticed that these contracts are not available in Teton: mini copper mini heating oil mini gasoline Would you please consider make available at least the mini copper? Thank you |
[2024-04-07 21:12:45] |
Sierra_Chart Engineering - Posts: 14423 |
We will make sure these are all added. Allow a few days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-18 15:16:30] |
After reviewing these contracts, they have very little volume and open interest. We will not be adding them or supporting them. You will need to use the micro contracts instead. For example micro Copper is supported (MHG).
