Date/Time: Sun, 05 May 2024 15:25:53 +0000
EDIT LONG LINE AT TOP OF CHART
View Count: 918
[2014-08-13 12:52:29] |
Meritus - Posts: 164 |
Please can you advise how I can edit the long line of data which appears at the top of the chart which begins with the symbol code and includes the date, time, high, low etc. Is there a way to un-check some or all these options? Thanks in advance
Date Time Of Last Edit: 2014-08-13 12:54:02
[2014-08-13 16:19:49] |
This is controlled through Global Settings >> Customize Chart Header.
