Date/Time: Sat, 04 May 2024 11:12:51 +0000
1173 problem with 'clear recent bid/ask volume' on TradeDOM
View Count: 968
[2014-08-13 11:36:00] |
Joe Hobart - Posts: 89 |
just upgraded 1170->1173 and seeing that clear volume isnt working to reset the volume column on the tradedom.
[2014-08-13 16:27:21] |
This will be resolved. For now, right click on the price scale and select the Clear Recent Bid/Ask Volume command.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 16:28:09
[2014-08-13 16:30:33] |
bwalks123 - Posts: 122 |
I am having the same issue, great cant wait till the problem is resolved as the recent bid ask volume feature gets to crowded without the ability to clear out old volume. Also is there a possibility to add an actual button on the trade DOM itself to clear the bid ask volume without having to click the Menu button and select that option? Keep up the great work SC rules..... Thanks |
[2014-08-13 16:34:34] |
Thanks SierraDevs for the EZ workaround. i was actually happy to learn it was on the right click menu. i would love exposure via a toolbar command or dom button, i use it every time i am filled to open to get a 'clean slate' |
