Date/Time: Wed, 01 May 2024 05:53:13 +0000
Forward projected pivots lines have stopped working?
View Count: 869
[2014-08-13 09:55:41] |
Danny J - Posts: 12 |
My forward projected pivot lines used to plot and be seen prior to them fixing and for some reason they have now stopped working? Why is this please? Within my Settings and Inputs 'studies to Graph' It is still checked 'yes' this has not changed. Please explain. |
[2014-08-13 10:54:06] |
The easiest way to determine the problem is for you to create a Chartbook containing one chart and only 1 chart. This chart needs to have the Pivot Points study demonstrating the problem. Here are the instructions to attach a Chartbook: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Please do not attach one of your existing Chartbooks. It needs to be a new one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 10:54:27
