Date/Time: Tue, 21 May 2024 05:28:05 +0000
Accessing Bid Vol - Ask Vol Values at Individual Prices Within a Number Bar
View Count: 73
[2024-04-02 17:24:24] |
TraderBiku - Posts: 20 |
Hello, I am wondering if it is possible to create an alert function based on the Actual Volume Compare Thresholds feature in the number bars study. For example, if I am using a 9-Range number bar, is it possible to create an alert (either for generating a bar alert or an automated trading alert) based on whether there are any price levels within that 9-Range bar that fulfill the third value of the Actual Volume Compare Threshold feature? Another way of saying this would be - is it possible to access the Bid Vol - Ask Vol of individual prices within the number bars through any other study in order to use that information to create custom alerts - Thanks very much - please let me know if the question needs to be clarified - |
[2024-04-02 20:16:50] |
Sierra_Chart Engineering - Posts: 14436 |
You can do this, with this study: Volume at Price Threshold Alert V2 You can also modify the study to meet your requirements: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
