Date/Time: Thu, 16 May 2024 07:37:06 +0000
Connecting to Apex via Rithmic
View Count: 155
[2024-04-02 15:53:09] |
User910357 - Posts: 2 |
I get in contact with APEX, from there side everything is normal. they told me that problème came from SC in attached the message log of my SC, there is no "DTC-log on error" message write on it, like in the link you send me before. I follow the procedere but doesn't help, looks that there is something else i need to connect to my ritmic trader pro accound pretty soon cause the qualification end soon thanks BR |
Screenshot 2024-04-02 174320.png / V - Attached On 2024-04-02 15:53:00 UTC - Size: 91.97 KB - 29 views |
[2024-04-03 01:47:46] |
Sierra_Chart Engineering - Posts: 14362 |
Refer to: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Make sure you have entered the correct, username and password for Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
