Date/Time: Thu, 16 May 2024 15:07:28 +0000
Problemy z danymi w czasie rzeczywistym
View Count: 83
[2024-04-02 10:01:25] |
User733449 - Posts: 4 |
I have updated Sierra Chart to version 2625 but when I try to connect, a message appears: "Real-time market data only supported with Sierra Chart data feed for symbol: F.US.CLEK24. ID:1." So far, I have been using package #10 connecting via CQG, AMP account. I have already: - tried forced login - made sure I have money What should I do? |
[2024-04-02 23:05:43] |
Sierra_Chart Engineering - Posts: 14363 |
We apologize for the delay on this. Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
