Date/Time: Mon, 29 Apr 2024 10:00:41 +0000
Transfering SC configuration
View Count: 886
[2014-08-13 03:02:33] |
User80177 - Posts: 29 |
I am currently using ATCharts (SC version 1136). To trial SC with Interactivebrokers, I've installed a second SC version 1136 in a different folder. Which config files should I transfer from the ATChart install to the new IB install in order to retain a) sound alert assignments and b) the customized toolbar and drawing preferences. Thanks Date Time Of Last Edit: 2014-08-13 03:13:40
[2014-08-13 07:53:35] |
You need to copy Sierra3.cfg. This is in the main Sierra Chart folder.
