Date/Time: Sun, 05 May 2024 09:50:53 +0000
Orders and Position Description - Field label missing
View Count: 897
[2014-08-12 22:00:30] |
pedro.gomes - Posts: 13 |
Hello, using CTS T4 FIX - connection, in the "Orders and Position Description", Balance Tab, a description error is presented bellow the trade account number. It looks like a missing field label: "22-3B9D-4C1D-xxxx-xxxx...". Please see attached image. Thank you PS. By the way, keep the good work I really like your trading platform. P.Gomes |
Orders And Position Description Error_1.PNG / V - Attached On 2014-08-12 21:52:58 UTC - Size: 18.99 KB - 315 views |
[2014-08-13 03:17:44] |
What you are seeing is the internal identifier used by the CTS T4 system for an account. In the next release these will not be displayed.
