Date/Time: Sun, 19 May 2024 15:52:34 +0000
Disable auto zoom in and zoom out in Candle Stick Charts
View Count: 91
[2024-03-31 11:54:56] |
User493067 - Posts: 1 |
Hello, when I scroll through my Candle Stick Charts it happens that it zooms in and out automatically. I triet to disable the Interactive scale function but it didnĀ“t work. |
Autoadjust1.png / V - Attached On 2024-03-31 11:54:03 UTC - Size: 64.11 KB - 28 views Autoadjust2.png / V - Attached On 2024-03-31 11:54:07 UTC - Size: 17.42 KB - 27 views |
[2024-03-31 18:32:35] |
Sierra_Chart Engineering - Posts: 14423 |
We are not understanding this. We recommend following through the instructions here: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
