Date/Time: Sat, 18 May 2024 15:24:25 +0000
Serious BUG in Chart Calculator VOLUME
View Count: 238
[2024-03-31 08:32:55] |
User346098 - Posts: 38 |
Hi, Chart Calculator has a bug when seeing the volume with "Show Volume". I can see you are using was a signed int to store the volume because it goes negative pass 2,147,483,647 and rotates Why do you not use one of those BigNum and variable precision arithmetic libraries to display any size of volume ? or this https://discuss.codechef.com/t/computing-factorials-of-a-huge-number-in-c-c-a-tutorial/1727 ? |
[2024-03-31 18:24:28] |
Sierra_Chart Engineering - Posts: 14423 |
What is the symbol of the chart?
[2024-03-31 18:42:50] |
Anyway, we will change the data type to double. It is a 32-bit signed integer but that is normally more than enough capacity for the purpose.
[2024-03-31 21:35:56] |
It's NVDA it has massive volume, applying from 2023-01-06 to 2023-11-22 the volume overflows a number of times can you make it 'unsigned long long' , why does it need to be 'double', volume is always an integer no 544.33 volume, and unsigned it's always positive or 0 Date Time Of Last Edit: 2024-03-31 21:37:21
[2024-04-04 10:36:38] |
Penny stocks can also have massive volume because of their low price OCGN 2021-3-11 it overflows instant |
[2024-04-17 20:39:40] |
Please also would like to request to change the limit to higher atleast unsigned long ( or equivalent ) the Volume Per bar "Bar period type" and all the Cumulative Delta Bars study. again see OCGN 2021-04-01 together with Chart Calculator I am counting the number of bars to compare volumes Thanks. |
[2024-04-17 21:28:34] |
We are not able to make any changes at this point in time with that. That is difficult assuming that it is not already a 64-bit value. It may be 64-bit already.
