Date/Time: Wed, 01 May 2024 06:04:46 +0000
Closed chart
View Count: 883
[2014-08-12 21:43:35] |
User57072 - Posts: 49 |
I accidentally closed a chart i had done a lot of work on. Is there anyway i can get it back ?
[2014-08-13 00:26:00] |
Yes. If you previously saved the Chartbook it is part of at the time the chart existed, then close the Chartbook with File >> Close Chartbook, do not save it, and open the Chartbook again.
