Date/Time: Mon, 06 May 2024 16:49:00 +0000
V.971 and Transact
View Count: 2772
[2013-05-06 15:30:54] |
Carl71 - Posts: 125 |
Just installed V971 Prices on SC DOM update more slowly than TransAct Dom So I've downgraded to V969 and works perfectly in line with the Transact Dom What's the issue? Date Time Of Last Edit: 2013-05-06 15:33:09
[2013-05-06 23:48:55] |
In the next release you will see this option in Global Settings >> Data/Trade Service Settings for TransAct: UpdateMarketDepthOnlyOnTrades You will want to disable it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-07 14:05:01] |
Take a look at this brief video that I have attached V971 SC DOM lags about 30 seconds Please see when the price of 1618.75 is hit by TA DOM and when is hit by sc DOM Back to V969 Date Time Of Last Edit: 2013-05-07 14:13:39
SC DOM LAGS.avi - Attached On 2013-05-07 14:13:30 UTC - Size: 12.54 MB - 586 views |
[2013-05-07 16:09:37] |
This is something we do not have control over. This is based upon the data feed itself.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-07 16:09:56
[2013-05-07 16:47:24] |
In the past, do you know if you were using a UDP connection to TransAct from within Sierra Chart?
[2013-05-07 17:00:38] |
Yes UDP connection In v971 there is no choice from UDP to TCP I think V971 uses TCP and it's very bad Can you confirm this? Please allow us to use UDP, otherwise I will use always V969 (the last version with a choice of Pricing protocol mode) I can't trade with 30 seconds of lag Please see the video Date Time Of Last Edit: 2013-05-07 18:30:25
[2013-05-07 18:31:24] |
Yes UDP Please restore the UDP connection Date Time Of Last Edit: 2013-05-07 18:33:49
[2013-05-08 07:12:21] |
SC can you reply on this?
[2013-05-08 07:38:44] |
We should have a new release out later this evening with the UDP and TDP option.
[2013-05-08 07:57:15] |
Thank You
