Date/Time: Thu, 16 May 2024 11:00:40 +0000
[Programming Help] - so many trades entry on same time
View Count: 152
[2024-03-25 17:28:47] |
User748811 - Posts: 16 |
I create a spreadsheet system,just practise. As you can see in attachment, why so many trades entry on same time? It looks very abnormal. 2. OR(AND($J$8 > 0, ID0.SG4@$3 0, ID0.SG4@$3 >= $J$9+2, is $ necessary be added? |
Trades on same time.png / V - Attached On 2024-03-25 17:28:33 UTC - Size: 385.34 KB - 27 views TradesList.txt - Attached On 2024-03-25 17:28:40 UTC - Size: 27.89 KB - 22 views |
[2024-03-25 18:50:26] |
Sawtooth - Posts: 3997 |
Probably because:- Signal Only On Bar Close is set to No - Signal Only Once Per Bar is set to No - Several other possibilities is $ necessary be added?
Yes, in formulas in Formula Columns.
[2024-03-26 15:31:03] |
I tried set Signal Only On Bar Close yes or noļ¼set Signal Only Once Per Bar yes or no. But there are still too many trades that occur at the same time and are all exit on 1 tick stop-loss. How do I need to export my testing spreadsheet strategy to you to make it easier for you to find the bug? |
[2024-03-26 15:44:23] |
Please tell me username of sc support, want to share my chartbook and study and spreadsheet system to you
[2024-03-26 15:45:40] |
Firstly, I'm not SC Engineering; I'm only a user.Secondly, you can Direct Message me for contact info. |
[2024-04-01 13:16:54] |
I am sure there is no multiple entry in same bar if i choose "Accurate TradingSystem Back Test Mode", My fault because i choosed "Standard Replay" last time.
