Date/Time: Tue, 14 May 2024 02:07:09 +0000
volume numbers in my chart
View Count: 90
[2024-03-25 16:53:26] |
georg2000 - Posts: 6 |
Good day I would like to show the volume numbers in my chart, with a volume number and line for the position. Current day. Previous day. Current week. Previous week. Current month. Previous month. Contract.Nr. Can you tell me where this is described? Link? How it works ? Via Market Profile? Import from other things via Study? Thanks for the help Greetings George |
[2024-03-25 20:37:31] |
John - SC Support - Posts: 31602 |
First, make sure you understand the difference between the reported Daily volume and what you would get by summing the data in an Intraday chart. Refer to the following: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume For performance we recommend using the "Summation of Study Subgraph - Periodic" and then combine that with the "Spreadsheet Study" to put the data together and display it as you want. Refer to the following: Summation of Study Subgraph - Periodic Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
