Date/Time: Tue, 14 May 2024 14:21:53 +0000
install Sierra Chart on second machine
View Count: 95
[2024-03-25 10:19:43] |
Mustang77 - Posts: 122 |
Hi I have Sierra chart on my main PC, version 2624, all good. since i'm travelling next week, i'd like to take my laptop, is it possible to install Sierra Chart on my laptop and have the same functionality as my PC ? Thank you |
[2024-03-25 14:02:47] |
John - SC Support - Posts: 31602 |
Yes, this is not a problem. Refer to the following regarding setting up another installation - the choice of which method to use is up to you: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation The only thing to note is that you are setup to only get the data to one system at a time. Therefore, you will need to ensure that your main computer is not running Sierra Chart when you are trying to use your laptop. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
