Date/Time: Mon, 29 Apr 2024 10:31:16 +0000
log message window
View Count: 960
[2014-08-12 04:50:21] |
User021827 - Posts: 174 |
How can I keep the log msg window from popping up in middle of screen ? Can the settings be changed on this window ? regards |
[2014-08-13 08:55:57] |
You cannot, but there is a reason why it is opening. What message does it display when it opens? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-13 12:43:58] |
I have some things in autotrading spreadsheets that cause message log to pop up. They are as expected and nothing is wrong, but I thought I could have the pop up off to the side or something. thanks regards |
[2014-08-13 16:20:52] |
Are you referring to the Message Log or the Trade Service Log?
[2014-08-13 16:51:02] |
mostly the trade service log
[2014-08-13 16:57:18] |
We are not sure what messages are appearing but uncheck: Global Settings >> General Trade Settings >>Open the Trade Service Log When New Message is Added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-13 21:24:17
[2014-08-13 19:00:35] |
ok just messages about trades being ignored for various reasons. ( according to my settings) . The messages are legitimate, I just dont need to see them all. thanks for the info. regards |
[2014-08-13 21:24:58] |
Unchecking the option described in post #6 will solve this. The Trade Service Log will not automatically open but the messages will still be added. There is no way to prevent those messages from being added. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-13 22:41:56] |
Thank you for the information. regards Shane |
