Date/Time: Thu, 09 May 2024 21:01:54 +0000
Numbers bar - value area
View Count: 100
[2024-03-23 13:53:46] |
User377189 - Posts: 154 |
for each number bars formed can i add value area to each bar just as TPO chart VA's
[2024-03-24 14:56:11] |
John - SC Support - Posts: 31506 |
If you want the Volume Value Area, then the easiest thing is to add the "Volume by Price" study to the chart and set the following Inputs: - Draw Mode: POC, VAH, VAL, and VWAP Lines Only - Volume Graph Period Type: Multiple Profiles Based on Bar Count - Number of Bars for 'Based on Bar Count': 1 Set the subgraphs as you want to see the Value Area as you want. Refer to the following: Volume By Price Study: Draw Mode If you want to see the TPO Value Area, then you would need to add the "TPO Value Area Lines" to the chart and set the Time Period to match the bars (this will only work with time-based bars). Refer to the following: TPO Value Area Lines You could also do the same with the "Volume Value Area Lines" if you prefer to do that rather than the "Volume by Price" study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
