Date/Time: Thu, 09 May 2024 04:07:09 +0000
Dark Mode
View Count: 197
[2024-03-22 20:35:34] |
User688525 - Posts: 191 |
Hello Sierra, If "Dark Mode" has been enabled, is it possible for this to be remembered as it appears that it will only last a couple of days before reverting back to a white background? Thank you |
[2024-03-22 23:02:53] |
John - SC Support - Posts: 31480 |
We do not have an explicit "Dark Mode" in the software. Are you referring to the website? What exactly is reverting on you? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-23 07:19:14] |
Hi John, Yes, the website. The dark theme is reverting back to the default white theme after a couple of days. |
[2024-03-23 09:48:58] |
Sierra_Chart Engineering - Posts: 14283 |
We will check on this and make sure it is saved.
[2024-03-23 21:55:31] |
Thank you!
[2024-03-23 23:34:30] |
Sierra Chart - Max - Posts: 5608 |
Hello, what browser are you using? And do you clear your browser sessions and/or cookies?
Sierra Chart Support |
[2024-03-24 02:25:49] |
Hello Max, Google Chrome is the browser. No, sessions and/or cookies aren't cleared. |
