Date/Time: Wed, 01 May 2024 11:54:49 +0000
datetimetostring
View Count: 912
[2014-08-12 02:08:19] |
onnb - Posts: 661 |
is this intended as a public method? if yes, can you add docs for the Flags parameter?
[2014-08-13 10:47:07] |
We will work on documentation for this.
[2014-08-13 10:48:12] |
You can find the available Flags constants for this function near the end of the SCConstants.h file.
