Date/Time: Tue, 14 May 2024 01:55:58 +0000
Trade Activity Log Quick Filter
View Count: 375
[2024-03-19 21:51:30] |
User924125 - Posts: 11 |
Hi, the trade activity log used to have a quick dropdown filter in the top row. Did this get removed in the latest updates? Maybe I changed a setting?
[2024-03-19 23:33:33] |
Sierra_Chart Engineering - Posts: 14341 |
All of the settings to control what is displayed in the Trade Activity Log now can be opened through the "DisplaySettings" menu command at the top of that window. This opens a window where all of the settings are located. This settings window can stay open continuously. Just press Apply or OK to apply them.
[2024-03-22 15:37:41] |
User695518 - Posts: 50 |
I would like to express that in my opinion this is a huge feature regression. The quick filter was just so much more user friendly and efficient...
[2024-03-22 16:43:15] |
User133797 - Posts: 1 |
Before the update it was possible to filter different notes in the trade activity log. Now I can only select "All notes" even though I have documented several notes (see screenshot). How can I filter these notes now? Thank you! P.S.: I also think that the previous quick filter was more user friendly. Date Time Of Last Edit: 2024-03-22 16:44:09
Screenshot_Activity log filter.png / V - Attached On 2024-03-22 16:34:21 UTC - Size: 54.42 KB - 54 views |
[2024-03-22 18:00:32] |
I also agree with the above posters that the previous quick filter was much better (quicker and easier) than the new way. If possible to bring back, that would be amazing.
Date Time Of Last Edit: 2024-03-22 18:05:30
[2024-03-22 21:16:13] |
We have to see why the Notes are not listed. We will resolve that. It is not intended that there are no Notes listed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-23 01:41:35
[2024-03-23 01:41:42] |
This is resolved in version 2623.
[2024-03-25 17:09:20] |
User2069 - Posts: 13 |
Would like to add another +1 to that request of at least having the option to switch back to the old look, this truly feels like a downgrade in every way.
[2024-04-27 14:43:20] |
Sorl4c - Posts: 5 |
I think the same, the fast filter from before was much more convenient.
[2024-04-28 14:02:42] |
Regarding this we want you to update to the latest release which is now 2632. Instructions: Software Download: Fast Update And the Display Settings can be left always open and just moved to the side and made narrow, to have the settings available for quick changing. If you have multiple monitors it can even be placed on another monitor. More information: Trade Activity Log: Notes About New Trade Activity Log Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
