Date/Time: Tue, 28 May 2024 02:37:42 +0000
Recalculate spreadsheet
View Count: 947
[2014-08-11 11:14:08] |
Outlander - Posts: 91 |
If I click ok in a cell the spreadsheet (NON-CLR) recalculates all formulas in the sheet. Is it possible to do that by auto on bar close or after a certain time? It would be a great help if possible. Regards Outlander |
[2014-08-11 11:17:24] |
Tell us what cell you modified.
[2014-08-11 11:51:34] |
Cell 3, I do not need to modify the formula in the cell only click ok and the whole sheet recalculate. It works on all formula columns cell 3. Regards Outlander |
[2014-08-12 00:38:05] |
We are checking on this.
[2014-08-12 10:22:30] |
Would this work sc.FlagFullRecalculate to recalculate the columns in the spreadshet? Is it indicator? Regards Outlander |
[2014-08-12 10:53:17] |
This is not an indicator and is not related to Spreadsheets.
[2017-01-21 18:55:39] |
opci - Posts: 90 |
if you can save this thread.ne were dead ends SCSS formula cell K3 and m3 is always lost when restart sierra.how to solve,, thanks. I tried file save as SCSS but sfter restart sierra formula disappear,, always |
[2017-01-21 19:04:42] |
opci - Posts: 90 |
File attached all I tried Date Time Of Last Edit: 2017-01-21 19:06:27
SCSS @@@.png / V - Attached On 2017-01-21 19:04:28 UTC - Size: 80.2 KB - 252 views |
[2017-01-22 08:52:17] |
The problem may be because of the Formula Source Sheet Number setting is not set correctly. This is documented here: Spreadsheet Study Inputs: Formula Source Sheet Number Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-23 17:48:16] |
opci - Posts: 90 |
sheet is ok ... or whether it is normal for me at all CHT appears scss..ali doing everything ok normal ... so be a nightmare?
[2017-01-23 18:20:02] |
We do not understand this: or whether it is normal for me at all CHT appears scss..ali doing everything ok normal ..
[2017-01-23 19:01:32] |
opci - Posts: 90 |
all have made sheet and save SCSS not save time or all but only save SCSS? when to do it appears to me SCSS on each Chartbook |
[2017-01-23 21:16:11] |
We are not understanding this.
