Date/Time: Wed, 15 May 2024 05:13:41 +0000
Current Price Line is NOT Accirate om amy Renko Chart Regardless of Mode
View Count: 162
[2024-03-13 14:48:37] |
User360283 - Posts: 440 |
3 Renko Charts 15-14-1 24-24-1 49-48-1 I added a 5 Minute chart for compassion Current price line inaugurate on all yet current price show highlighted in White om Price scale! Therefore Current Price Line is not current! Please fix Current Price Line Indicator Thanks |
[2024-03-13 16:57:06] |
John - SC Support - Posts: 31627 |
We need to see an image of what you are seeing. Please follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-03-14 18:03:33] |
how about you all creating your own Flex Renkos first I'm sure you will see the problem I have 3 Remkos and one 5 minute All are st to automatic Current price is wrong on all! It seems to be several bars behind! Worst is the 49-48-1 Renko Please fix this Thanks |
[2024-03-14 19:33:41] |
We put on a Flex Renko with 49-48-1 parameters and the Current Price Line and the Current Price Line lines up exactly as it should. Attached is an image of what we see with the Current Price Line in Green and 6 pixels thick (so it can easily be seen).
Sierra_Chart_MainWindow_2024-03-14 14_31_50.877.png / V - Attached On 2024-03-14 19:33:18 UTC - Size: 150.53 KB - 28 views |
[2024-03-27 00:37:06] |
Current Price Line still incorrect on all my Renko charts My analysis: Current Price Line does NOT align with Highlighted White Price on chart right edge It is always NN point above or or bellow by a few points It seems to align for only 1 bar when the bars go from red to green and vice versa At the next bar it becomes incorrect Therefor I suspect the is a coding error Please fix Thanks |
[2024-03-27 01:08:32] |
Sierra_Chart Engineering - Posts: 14353 |
Follow through the instructions here to resolve this: Chart Scale and Scale Adjusting: Maintaining Same Scale for Multiple Graphs in Chart Region Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-15 20:45:09] |
Current Price line is still FUBAR! Off 5 points in Flex Renko 10-9-1 Off 10 points in Flex Renko 25-24-1 Off 20 points in Flex Renko 49-48-1 Your referral to Chart scale was a waste of time Simply put to Current Price lie code needs a fix! Please Thanks |
[2024-04-16 14:11:48] |
There is nothing wrong with the Current Price Line study. We are still waiting for you to give us an image of what you are seeing. Please follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Also, on your Current Price Line study, what is the Input for "Input Data" set to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-16 14:52:51] |
I changed one Renko to a 5 minute and the Current Price Line was still inaccurate Then I deleted all other studies on the chart and there was bout a 50% improvement Still the Current Price line did not agree with the prices on the stand alone DOM So I deleted the Current Price Line and I give up! Maybe you will spend some time fixing the Current Price Line on Renkos with the Stand Alone DOM? Please let me know Thanks |
