Date/Time: Fri, 03 May 2024 03:53:23 +0000
GANN DEGREE ON CHART CALCULATOR
View Count: 1401
[2014-08-08 18:19:09] |
michelh - Posts: 159 |
Hi SC, Can I please request that the chart calculator have a feature for calculating Gann square of 9 degrees between two points? This will avoid always reaching for the calculator to do square root calculations which is rather tedious. I would imagine it would be easy to implement (difference of square roots x 180). I Would very much appreciate with next version, as I am sure other Gann traders would. With thanks, Michel |
[2014-08-09 14:30:19] |
also, please on the OHLC tool, if you could add an option to also display the square root of the price, that would be fantastic. with thanks, Michel |
