Date/Time: Wed, 15 May 2024 20:58:11 +0000
[User Discussion] - Charts are copied to other chartbooks
View Count: 96
[2024-03-09 20:51:08] |
stonecoldtrader - Posts: 1 |
I have charts that are getting copied over to other chartbooks (not just drawings, entire charts). I cannot
Chartbook1.jpg / V - Attached On 2024-03-09 20:49:47 UTC - Size: 928.57 KB - 27 views chartbook2.jpg / V - Attached On 2024-03-09 20:50:03 UTC - Size: 953.17 KB - 27 views Attachment Deleted. |
[2024-03-11 16:07:44] |
John - SC Support - Posts: 31659 |
The charts are not being copied. Most likely, you have the option for "Window >> Window Always Visible" enabled for those charts. This option makes it so the charts are still visible when you change chartbooks. Refer to the following: Window and CW Menus: Window Always Visible (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
