Date/Time: Mon, 06 May 2024 03:46:35 +0000
Kagi Chart Option Not visible
View Count: 890
[2014-08-08 04:46:04] |
lamrin - Posts: 2 |
Hello, I am a new user of Sierra charts although a lot of experience using other options.The main feature I am looking for is "Kagi" Charts.I dont find it however in the options under "Chart---Graph Draw Times". First off, I want to make sure that I am using the Level 5 version which I believe all the 2 weeks trail are set for.Kindly confirm this as well. Regards Lamrin |
[2014-08-08 04:50:21] |
lamrin - Posts: 2 |
Hello, I managed to find it under Analysis---Studies.I will test Kagi charts and post any queries if I have. Sorry for the unnecessary post. Regards Lamrin |
[2014-08-08 05:55:47] |
Level 5 version which I believe all the 2 weeks trail are set for.Kindly confirm this Yes, your account is on package 5.
as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
