Date/Time: Sun, 19 May 2024 00:37:23 +0000
TPO study split session profiles not giving correct values
View Count: 976
[2014-08-06 03:25:09] |
User91026 - Posts: 16 |
I am trying to get the TPO study to work properly. I have tried to search the support board but to no avail. Very likely I am missing something but I have been trying to sort it out for two days now. I was hoping someone would be able to help. I have setup the TPO as a day session from 9:30-16:15 and an evening session from 16:15:01-9:29:59. this works well on all other charts, volume profile, candlestick, renko etc. it's just the TPO study that I can't get right. For some reason, it is not displaying the Overnight or evening session and the day session correctly and i can't figure out what in the settings i need to change. i have followed the documentation step by step. I have attached 4 different images. 1) The session setting in Chart->Chart Setting 2a and 2b) The TPO settings 3) the actual TPO chart. As shown in image 3, the evening session for 8/4 is not displaying correctly and the high and upper distribution of 8/5 also not displaying correctly. Could you please help with this? Date Time Of Last Edit: 2014-08-06 21:55:59
[2014-08-07 02:59:40] |
We see that the Session Times are not set correctly for this chart and probably your other charts as well. We have prepared documentation explaining this type of mistake: https://www.sierrachart.com/index.php?page=doc/doc_SessionTimes.php#UnderstandingHMSPlaces Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
