Date/Time: Sun, 19 May 2024 07:44:31 +0000
Mr. Gene Sheldon
View Count: 969
[2014-08-05 12:46:16] |
User72965 - Posts: 114 |
I follow the ES mini Euro Oil Crude .. What do I need for these . I see 35 a month can get the cme .. Does this cover them ??? Currently have DTN for 96 a month . Wondering if I can cut the data feed cost ??? Thx Gene Sheldon~~~ Currently a Sierra Chart user ~~ Thx Gene :) |
[2014-08-05 15:36:23] |
You can reduce your data feed cost. However, do you have a live futures trading account? Refer to this section: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-05 15:38:41
[2014-08-20 17:05:08] |
yes have a acc't with Interactive Brockers Thx Gene My DTN up for monthly renewal 9-01-14 Like to try Sierra then ~~ |
[2014-08-20 17:23:19] |
If you have an Interactive Brokers account , then you can use the Sierra Chart Real-time and Historical Exchange Data Feed and receive CME data at reduced exchange fees. Follow the set up instructions here: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
