Date/Time: Thu, 16 May 2024 13:53:01 +0000
Trade Activity Log - time range for the Period column
View Count: 179
[2024-02-16 18:39:17] |
User12089 - Posts: 350 |
Trade Activity Log / Period Stats Tab: when Period is set to Half Hour of Day or Hour of Day, what is the actual period / time RANGE in the Period Column of the generated report sheet? There is always only ONE value there e.g. "10:00" - so when it is 10:00 and the Period is set to Half Hour of Day, is the ACTUAL Time Range represented by "10:00": a) 9:30-10:00 OR b)10:00-10:30? Date Time Of Last Edit: 2024-02-16 18:39:51
[2024-02-16 19:40:40] |
John - SC Support - Posts: 31666 |
The displayed period time is the start of the period. So a value of 10:00 means a half-hour period starting at 10:00, therefore running from 10:00 to 10:29:59. If you do not see any other times listed, then you do not have any other trades outside of that 10:00 - 10:29:59 period. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-16 19:44:48] |
thanks, i do see other times displayed e.g.: 09:30 10:00 10:30 11:00 11:30 etc the question was whether e.g. "10:00" means 10:00-10:30 or 9:30-10:00 thanks for clarifying |
[2024-03-10 21:54:55] |
Sierra_Chart Engineering - Posts: 14362 |
Yes: the question was whether e.g. "10:00" means 10:00-10:30
