Date/Time: Mon, 06 May 2024 05:11:24 +0000
SC Data Feed
View Count: 987
[2014-08-04 22:38:21] |
User43916 - Posts: 9 |
Hi, could you do me a favor so I could compare your tick data to mine and just post a 5 minute chart of the ES with Cumulative Delta Bars Up/Down Tick Volume. I want to see if it's the same data as my current vendor. Much appreciated.
[2014-08-04 23:09:20] |
What is the time zone Sierra Chart is set to? And what are the Session Times you have set for the chart?. And are the Cumulative Delta Bars set to reset every day? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-04 23:42:23] |
EST 24hr - 5 minute bars Reset each day, yes. Thanks. |
[2014-08-05 05:00:44] |
Here is the chart image: https://www.sierrachart.com/image.php?l=1407214744338.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-05 12:21:27] |
Wow, a bit different than I am seeing now. Would you mind posting one more chart of something more volatile like CL or NG (same settings.) Thanks.
[2014-08-06 01:12:43] |
bump
[2014-08-06 03:21:06] |
We apologize for the delay. Here is an image of CLU4: http://www.sierrachart.com/image.php?l=1407295233772.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-06 03:57:41] |
Thanks.
