Date/Time: Thu, 05 Nov 2026 17:44:31 +0000
number bar
View Count: 760
| [2024-02-05 15:20:53] |
| Ngalylomqua - Posts: 4 |
I cant apply number bar to my chart, and i want my chart to look specific like this https://ibb.co/hCGFB8M
| [2024-02-05 17:50:21] |
| John - SC Support - Posts: 48447 |
You are on package 3 and need to be on one of the "Advanced" packages to have access to the Numbers Bars. Refer to the following: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-02-05 17:57:55] |
Ok done purchase the plan and what are the steps that i can have a chart like i want to
| [2024-02-05 18:14:43] |
You are still on Package 3. Refer to the following to change your package: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. To setup the Numbers Bars, follow the instructions here: Numbers Bars: Step-By-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2024-02-06 09:53:11] |
| User727034 - Posts: 21 |
I spent several hours following the step by step guide and several more videos on how to install the Numbers Bars study (Using package 10 and delayed data ) but cannot get any chart to appear when I apply Numbers Bars study. The chart goes blank. All that appears is the Current Price Line study that was added manually separately. Is there a trouble shooting guide that can be followed or even a basic template that can be used to get started?
| [2024-02-06 16:24:04] |
Package 10 does not support the Numbers Bars study. You need to be on one of the "Advanced" packages. We see that you are currently on Package 11, so you should be good now. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
