Date/Time: Mon, 21 Sep 2026 18:50:44 +0000
[Programming Help] - Configuration Trouble
View Count: 560
[2024-02-03 18:07:13]
Mataxa - Posts: 1
I'm new to sierra and can't figure out my setup. I would like to have a footprint with a data table. I can't make the columns larger and the table smaller. All the tutorials I find always have a larger column size. I put two photos in the description.
Thank you
imagefinal_chart.jpg / V - Attached On 2024-02-03 18:00:55 UTC - Size: 200.84 KB - 145 views
imageinitial_chart.png / V - Attached On 2024-02-03 18:01:06 UTC - Size: 328.42 KB - 190 views
[2024-02-05 16:37:20]
John - SC Support - Posts: 47955
You need to expand your bar spacing. Refer to the following:
Numbers Bars: Scaling a Numbers Bars Chart
