Date/Time: Tue, 30 Apr 2024 14:34:24 +0000
spreadsheet converter failure
View Count: 1073
[2014-08-01 23:18:36] |
User021827 - Posts: 174 |
since updating software, this message appears. I use non clr version. Failed to launch C:\SierraChart\SpreadsheetFileConverter.exe. Windows error code 2: The system cannot find the file specified. | 2014-08-01 19:15:28 Unable to open C:\SierraChart\Data\DefaultSpreadsheetStudy.scwbf because the spreadsheet file conversion failed. | 2014-08-01 19:15:28 thanks |
[2014-08-02 00:07:26] |
Were you previously using the non-CLR version? If so, then you can rename this file to something different: DefaultSpreadsheetStudy.scwbf So it is not going to get used and cause these error messages. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-02 00:35:47] |
hi yes I was using non clr previously ok, thanks for quick reply ! regards |
