Date/Time: Sun, 19 May 2024 15:10:40 +0000
Server Side User Profit/Loss Management
View Count: 320
[2024-01-26 04:20:38] |
Oxcap - Posts: 55 |
Hi Support, I watched the demonstration video on how to set up the user profit/loss management functionality. https://www.sierrachart.com/index.php?page=doc/VideoLibrary.php&Video=Server_Side_User_PL_Management I'm using a trading evaluator connection on a VPS testing a strategy and want to implement a profit trigger to flatten position if met. See screenshot of my edit trade account: 0000. You will see my loss management is set at -500 but the profit loss value after profit trigger does not show 800. I ran a chart replay test to see if the loss management would trigger but it didnt either. I checked Global Profit/Loss Management to see if there might be something conflicting but there is nothing enabled from that setting. Would I have to enable and/or match that setting too? See attached global profit/loss management screenshot? In summary, I have three trading evaluator accounts I would like to set separate profit/loss management for. Any help with setting this up is appreciated. Let me know if you have any questions. Thank you in advance for your help. Hai-Nam |
User ProfitLoss Management Screenshot.png / V - Attached On 2024-01-26 04:06:23 UTC - Size: 158.13 KB - 52 views Global Profit_Loss Management.png / V - Attached On 2024-01-26 04:10:51 UTC - Size: 51.55 KB - 49 views |
[2024-01-26 15:47:22] |
John - SC Support - Posts: 31728 |
We just tested the loss trigger to ensure that it is working properly, and it worked as expected. Keep in mind, the Trading Evaluator "User Profit/Loss Management" does not work in replay. When running a replay, the system is in Simulation Mode. With regards to the profit, you need to first hit the trigger value of 1000 and then the "Profit Value After Trigger to Flatten Positions in Account Currency" will kick in. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-26 16:58:07] |
Oxcap - Posts: 55 |
ok - regarding replay mode 2 of 3 three accounts I set for the profit trigger executed today and flatten positions. My next question is how I can see the trigger value of 1000 under 'read only values'? It appears the profit management is working but I am not able to see under 'read only values' at the bottom. Thanks, Hai-Nam |
[2024-02-05 02:20:50] |
Sierra_Chart Engineering - Posts: 14423 |
Be sure to press the Update button to update those values.
[2024-02-05 15:03:24] |
Oxcap - Posts: 55 |
I made sure to click update several times based on the steps from the video.
[2024-02-05 15:23:14] |
Ok we are not understanding the problem then. We need a clear explanation of exactly what the issue is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-25 01:33:10
[2024-03-25 00:34:49] |
Oxcap - Posts: 55 |
I have figured out my problem. Ticket is closed. Thank you.
