Date/Time: Thu, 10 Sep 2026 07:23:41 +0000
Need help finding the symbol SPY.
View Count: 2063
| [2014-08-01 16:58:41] |
| User48557 - Posts: 138 |
I already purchased ''Sierra Chart Real-time and Historical Exchange Data Feed'' for the 35$ and then selected (CBOE) and also purchased and activated that as well. Now when i log onto my Sierra chart i do not know where to find this new service i apparently activated. Everything seems the same with my account.
| [2014-08-01 17:32:45] |
So you want to chart the SPY? For this you will need to activate the US equities exchange: https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges Not the CBOE Indices exchange. You will have to complete the NYSE and NASDAQ exchange agreements before you can activate the US equities exchange. Once you have activated this exchange, restart Sierra Chart and then open a chart for SPY by manually typing it into the Selected Symbol box in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-08-01 18:44:27] |
I have also activated the US equities exchange and went threw all the licence agreements as well. I still cant find SPY
| [2014-08-01 19:16:02] |
You will not find it. You have to manually type it as we previously said: Once you have activated this exchange, restart Sierra Chart and then open a chart for SPY by manually typing it into the Selected Symbol box in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-08-01 19:22:01] |
Ok i got it now, thanks
