Date/Time: Thu, 02 May 2024 16:47:40 +0000
data feed open e cry
View Count: 2394
[2014-08-01 14:17:40] |
User84455 - Posts: 32 |
not working for the eminis like es ym nq oil you name it only russell seems to be working contacted them they said to contact you
[2014-08-01 14:22:41] |
MonteCarlo64 - Posts: 23 |
I also am not getting real time ESU4 data from OEC this AM.
[2014-08-01 17:12:52] |
Refer to help topic 3: Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html If you are still having a problem, we need to see the Message Log. Here are the instructions to post it: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-08-01 19:20:54] |
File >> Disconnect selected. | 2014-08-01 15:18:46 OEC FIX Trading: Sending a Logout message. | 2014-08-01 15:18:46 OEC FAST Data: Sending a Logout message. | 2014-08-01 15:18:46 Disconnected from Open E Cry. | 2014-08-01 15:18:46 Socket closed. No error. | 2014-08-01 15:18:46 Socket has been shutdown and closed. | 2014-08-01 15:18:46 OEC FAST Data: Remote side disconnected without completing the logout sequence. Final messages may have been lost, although unlikely. | 2014-08-01 15:18:46 Open E Cry FIX/FAST: Disconnected from the market data server. | 2014-08-01 15:18:46 OEC FIX Trading: Received a Logout message. | 2014-08-01 15:18:46 SSL shutdown indicates not able to send 'close notify'. | 2014-08-01 15:18:46 The SSL socket was shut down. | 2014-08-01 15:18:46 The SSL socket object has been freed. SSL state is now disconnected. | 2014-08-01 15:18:46 Socket has been shutdown and closed. | 2014-08-01 15:18:46 OEC FIX Trading: Logged out and disconnected. | 2014-08-01 15:18:46 Disconnected from the Open E Cry FIX Orders server. | 2014-08-01 15:18:46 Disconnected from Open E Cry. | 2014-08-01 15:18:46 NOTICE: The Sierra Chart relay server was not created because the relay port number is not set. If the relay server is needed, set the port and reconnect. | 2014-08-01 15:18:49 Open E Cry FIX/FAST - Connecting to trading server prod.openecry.com:9400. | 2014-08-01 15:18:49 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-01 15:18:49 The network socket is connected. | 2014-08-01 15:18:49 Starting SSL connection on the socket. | 2014-08-01 15:18:49 SSL socket is connected. | 2014-08-01 15:18:49 OEC FIX Trading: Sending the Logon message. | 2014-08-01 15:18:49 Open E Cry FIX/FAST: Connected to trading server. | 2014-08-01 15:18:49 Open E Cry FIX/FAST: Connecting to FAST market data server: prod.openecry.com:9301. | 2014-08-01 15:18:49 Resolved address prod.openecry.com to IP 64.94.37.206 | 2014-08-01 15:18:49 The network socket is connected. | 2014-08-01 15:18:49 OEC FAST Data: Sending the Hello message. | 2014-08-01 15:18:49 OEC FAST Data: Sending the Logon message. | 2014-08-01 15:18:49 Open E Cry FIX/FAST: Connected to the market data server. | 2014-08-01 15:18:49 Open E Cry FIX/FAST: Connected. | 2014-08-01 15:18:49 Open E Cry FIX/FAST - Starting real-time market data updates for: ESU4 | 2014-08-01 15:18:49 Symbol Error - ESU4 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled | 2014-08-01 15:18:49 Symbol Error - ESU4 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled | 2014-08-01 15:18:49 HD Request # 6 - Downloading Intraday chart data for ESU4 to the file ESU4.scid. Service: oec | 2014-08-01 15:18:50 HD Request # 6 - Download start Date-Time: 2014-08-01 15:18:28.0 | 2014-08-01 15:18:50 HD Request # 6 - Using server: ds4.sierracharts.com port 10149 | 2014-08-01 15:18:50 Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-08-01 15:18:50 The network socket is connected. | 2014-08-01 15:18:50 HD Request # 6 - Sending historical data logon request message. | 2014-08-01 15:18:50 HD Request # 6 - Requesting Intraday data. Max. days to return: 186. Start Date-Time: 2014-08-01 15:18:28. Record interval: 0 . Symbol: ESU4 | 2014-08-01 15:18:50 HD Request # 6 - Decompressing data. | 2014-08-01 15:18:50 HD Request # 6 - Receiving Intraday data for ESU4 starting at 2014-08-01 15:18:28 | 2014-08-01 15:18:50 HD Request # 6 - Timestamp of first Intraday data file record written: 2014-08-01 15:18:32 | 2014-08-01 15:18:50 Socket has been shutdown and closed. | 2014-08-01 15:18:50 The network socket for historical data has been closed. | 2014-08-01 15:18:50 HD Request # 6 - Received 131 records from 2014-08-01 15:18:28 to 2014-08-01 15:18:41 (13.0 seconds) and wrote 111 records for ESU4 | 2014-08-01 15:18:50 HD Request # 6 - Intraday download COMPLETE for ESU4. Completion time: 0s | 2014-08-01 15:18:50 Real-time Intraday chart data file updates started for ESU4 | 2014-08-01 15:18:50 Requesting market depth updates for: ESU4 if supported. | 2014-08-01 15:18:54 Symbol Error - ESU4 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled | 2014-08-01 15:18:54 Open E Cry FIX/FAST: Received position acknowledgment message. Request Result: 2. Request Status: 1 | 2014-08-01 15:19:04 |
[2014-08-01 19:39:07] |
Contact OEC about this message: Symbol Error - ESU4 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled | 2014-08-01 15:18:49 They will be able to help you with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-08-01 19:39:23
