Date/Time: Thu, 16 May 2024 14:28:51 +0000
Descending Trade activity log
View Count: 271
[2024-01-24 18:33:17] |
karohm - Posts: 137 |
I have the descending display order checked but still the trades are not coming up in descending order in trade activity log. PFA screenshot |
Screen Shot Thu 01 25 2024 at 12.01 AM.png / V - Attached On 2024-01-24 18:33:04 UTC - Size: 24.88 KB - 40 views |
[2024-01-24 21:31:37] |
John - SC Support - Posts: 31666 |
For the "Trades" page, the information is grouped by symbol, then they are displayed in descending order.
[2024-01-25 06:44:06] |
I think even then its still not descending. Look at the first 2 MES trades. The older trade is coming before the newer trade. (Should be the other way). And can we have it not grouped by symbol and just be able to have every trade in descending order. Would be great. Helps journal my trades in order without having to figure out the order. Love the trade activity log. |
[2024-01-25 08:23:08] |
Sierra_Chart Engineering - Posts: 14363 |
How are you enabling the descending order? No this is definitively not possible at all: And can we have it not grouped by symbol
[2024-01-25 14:24:27] |
PFA screenshot
Attachment Deleted. Private File |
[2024-01-25 17:02:49] |
If you switch off "Descending Display Order" does the order of the two MES trades change?
[2024-01-25 17:09:55] |
Nope. Its staying the same
[2024-01-29 20:14:36] |
Determining the reason for this is quite involved. We are not really sure about this at this point in time. It is not something we can allocate any time too. Try selecting a specific account and not "All Accounts". And also a specific symbol. It may not work when using these settings for all accounts and all symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-01-30 11:59:01] |
Its alright, doesnt need to be looked at in urgency. Just to let you know: I tried to select specific account and symbol, still didnt work. |
[2024-03-25 16:45:49] |
Hi, The disable trade activity log and disable statistisc,trade,period tabs in trade activity log is not being remembered on SC start up. |
[2024-03-26 03:06:00] |
They are not remembered deliberately. We will add support to remember Disable Trade Activity Log.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-03-26 03:06:06
[2024-03-26 04:42:26] |
That would be great. Thank you so much.
[2024-03-26 17:03:02] |
Is this done in todays update ? |
