Date/Time: Fri, 03 May 2024 15:08:31 +0000
manual Draw lines and write on charts(Pencil)
View Count: 1809
[2014-08-01 09:29:59] |
apollofl - Posts: 95 |
can't find the pencil mode. would like to draw and make notes on chart. A free hand drawing tool Thanks Date Time Of Last Edit: 2014-08-01 09:35:31
[2014-08-01 10:20:38] |
This is not supported. There is a Type Text tool on the Tools menu. Refer to the documentation for more information. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
