Date/Time: Thu, 02 May 2024 00:15:06 +0000
Different scaling when resizing chart window
View Count: 1148
[2014-07-31 18:12:35] |
User22611 - Posts: 2 |
Hi, I have problem with scaling. When I resizing my chart window with numbers bars from original size (about 1/4 of desktop) to maximize, height of rows is too big (space betwen numbers is big). I must manually adjust back to comfortable (smaller) size. And next, when I restore window size back from maximized state, space between rows is too smal, if i reduced row space in maximize state. Numbers are overlapped. Se attached screenshots. Can you help me ? Im not understand your documentaion. Im sorry for my english. |
Snímek obrazovky 2014-07-26 v 15.08.38.png / V - Attached On 2014-07-31 18:12:10 UTC - Size: 73.35 KB - 405 views Snímek obrazovky 2014-07-26 v 15.08.48.png / V - Attached On 2014-07-31 18:12:15 UTC - Size: 217.52 KB - 377 views |
[2014-07-31 18:22:17] |
What you described is expected behavior. If you have to adjust the vertical scale after changing the size of the window, then this is what needs to be done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-31 18:28:37] |
It is possible to fix scaling ? So that when the window is resized, space between rows is the same as before ? Thanks. |
[2014-07-31 18:45:52] |
No. The Y axis location of a particular number is dependent upon the chart scale which starts covering a larger or smaller range of pixels as you increase or decrease the size of the window.
[2020-12-16 18:24:48] |
osaga - Posts: 53 |
SC Support Is it possible to create a toggled chart setting that when checked will keep the bar height (in pixels) the same height whether it is maximized or restored? In this case the scale would change, but the bar height stays the same. This would be extremely helpful. As the moment I have to have my charts from top to bottom of the screen to keep the bar height the same when maximized. Regards! |
