Date/Time: Sat, 04 May 2024 15:52:09 +0000
futures with 1/128 values show incorrect scale
View Count: 997
[2014-07-31 15:03:40] |
cmb999 - Posts: 211 |
it seems something is wrong with scale vaules, http://www.sierrachart.com/image.php?l=1406820721349.png Date Time Of Last Edit: 2014-07-31 15:33:11
[2014-07-31 16:52:51] |
This is now resolved. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Also apply the updated symbol settings to the chart: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps After both of these are done, then re-download the data in the chart by selecting Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-31 16:53:15
[2014-07-31 18:24:07] |
Ok. It seems 2-yr treasures (ZT) need same treatment, as well. thx. Date Time Of Last Edit: 2014-07-31 18:24:18
[2014-07-31 18:39:07] |
This has now been corrected as well. Follow these steps: Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps Also apply the updated symbol settings to the chart: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
