Date/Time: Wed, 08 May 2024 00:30:58 +0000
Moving Average get cut short
View Count: 969
[2014-07-31 14:20:58] |
User49789 - Posts: 6 |
Hi, My 100 EMA seems to get cut short in a couple of areas, is there a fix for this? I have attached an image. Thanks in advance. Andy |
100 ema.png / V - Attached On 2014-07-31 14:20:23 UTC - Size: 36.02 KB - 350 views |
[2014-07-31 17:00:01] |
This is an Intraday chart, therefore load more data into the chart by following the instructions in help topic 42.1 here: http://www.sierrachart.com/index.php?page=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
