Date/Time: Sun, 01 Nov 2026 03:26:39 +0000
Topstep and Sierra chart
View Count: 2295
[2014-07-31 06:53:45]
User17477 - Posts: 65
Hi Support,
I want to connect to Topstep as per this article
http://help.topsteptrader.com/knowledgebase/articles/211607-sierra-chart-connection-instructions
but also want to keep my current live broker account available. What is the best way to achieve this? Should i install another instance of Sierrachart? Do this work with my current subscription?
thanks
[2014-07-31 06:57:57]
Yes, definitely install another copy of Sierra Chart following the instructions here:
http://www.sierrachart.com/index.php?page=doc/MultipleServices.html
And use your existing Sierra Chart account to log into that copy. It will work with Top Step Trader or any service.
[2014-07-31 07:27:54]
So I can use both instances at the same time and also the Sierrachart data feed I subscribe to?
thanks
[2014-07-31 07:32:46]
Yes. If you want to use the Sierra Chart data feed in both copies of Sierra Chart, then you need to add a second market data connection for 20 USD.
[2014-07-31 07:50:40]
Are any orders sent to the server or local to my Sierra chart?
[2014-07-31 09:38:34]
When Trade >> Trade simulation Mode On is disabled, all orders are sent to the connected trading service.
