Date/Time: Fri, 03 May 2024 08:10:32 +0000
ACSIL - UseTool & Order lines related question
View Count: 1173
[2014-07-30 20:47:57] |
ejtrader - Posts: 688 |
SC Team - Trying to make use of some what virtual orders using ACSIL and trying to use some of the functionality that current Order related lines that are drawn. Question 1: - What fields needs to be populated to draw - DRAWING_ENTRYEXIT_CONNECTLINE / DRAWING_ORDER_FILL Question 2: - At present you draw "X" mark as part of the order line - Assuming you draw it and detect a click to cancel the order - Any way to achieve similar functionality ( to detect click on "X" mark ) through ACSIL? if not - would look at alternate ways to do this ( probably needs to use some other win32 programming aspects ). Hoping there is someway to get similar functionality through ACSIL itself. PS: Please don't mark this as user discussion - just yes/no questions are good enough. Thanks On a side note - there is a "typo" on this page about - SCT_OSC_ORDER_CANCELLED - It should have been SCT_OSC_ORDER_CANCELED ( or need to have constants updated ). https://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html#OrderModification http://screencast.com/t/MTQXGleWWn Date Time Of Last Edit: 2014-07-31 00:10:06
[2015-08-15 03:39:16] |
SC Team - Wanted to follow-up on this. Whatever you can answer without marking it as user discussion. Would you please review and update? thanks Date Time Of Last Edit: 2015-08-15 03:40:14
[2015-08-15 06:05:48] |
1. We do not think these are going to work and we do not know the answer to the question without research and this is beyond the scope of our support. 2. No, and the implementation of this is somewhat complex within Sierra Chart. The documentation has been corrected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-08-15 06:06:04
