Date/Time: Sun, 28 Apr 2024 21:40:37 +0000
Place a Limit Order on DOM
View Count: 1065
[2014-07-30 15:10:43] |
User96267 - Posts: 43 |
Hello SC-Community, how can I place a limit order on the trading DOM? I thought I have made all the settings to do so, but sometimes I think my order is executed when all limits of a price level are bought/sold. You see an image attached. Thanks in advance. Maximilian Fischer EDIT: Or is it because I'm in SIM Mode and I don't have a "place" in the limit queue? Date Time Of Last Edit: 2014-07-30 15:11:17
DOM_SC.JPG / V - Attached On 2014-07-30 15:09:38 UTC - Size: 44.92 KB - 400 views |
[2014-07-30 15:33:40] |
skoosht - Posts: 13 |
I believe in SIM mode price has to trade completely through the price to get a fill, otherwise fills would be unrealistically optimistic.
[2014-07-30 17:33:22] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_TradeSimulation.php#HowOrdersAreFilled https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-30 17:57:45] |
Thank you! That helps me very well. Best regards |
